04 Accent weak reverse harsh 2nd -3rd shift
Old 04-08-2012 | 10:20 PM
lee3393's Avatar
Thumbs up 04 Accent weak reverse harsh 2nd -3rd shift
Hello, Kind of a long description but here goes. I just got my 2004 Accent 1.6L Auto. It is great except the reverse is weak/slow to engage and sometimes chatters but will back car on level ground. Fluid was nearly a qt low/ filled to top of hot when hot and no change. It also holds second gear until dropping suddenly into 3rd. It also clunks into gear when slowing to a stop (one of the low gears second or first?). Other than this its smooth and strong and drives great in overdrive. Not sure where to go from here I have searched the threads and google not much similar to go on. Thanks in advance for any advice. Is my trans repairable?
LJ
Old 04-09-2012 | 02:41 PM
How many miles? Has the trans fluid ever been changed? It should be changed every 30K miles.
Old 04-11-2012 | 01:56 PM
lee3393's Avatar
Lightbulb Help!!
04 accent 145K I found it was nearly a qt low I dont know the service history. It seems to want to hold second longer than it should (3k rpm) Its shift quality varies sometimes is good but not usually its harsh. I found it had stored code p1709 I wonder if my kick-down servo is bad? They don't seem to be easily available, but is easy to get to. I read there is a TSB for it. Thanks for the reply. Lee
Old 04-12-2012 | 09:17 PM
lee3393's Avatar
Exclamation Kick-down servo switch
Well I removed the C clip ring holding the k/d servo switch in place. A little trans fluid came out about a teaspoon not sure if this area is supposed to be wet or dry. The switch was wet gonna try a new one. It backed up great after drying it out and cycling it. It never backed that strongly before. I also pulled on the pin that actuates the switch it didn't seem to bind at all. The car didnt want to back after driving a while. Stay tuned
Old 04-15-2012 | 07:10 PM
laughingoddess's Avatar
I had this issue, when the spark plugs were replaced it disappeared! I'm not a car mechanic so I'm not really sure why that helped, but it did lol
Old 04-18-2012 | 09:07 PM
lee3393's Avatar
Thumbs up Thanks
Did you replace them yourself? Thanks for the reply!
Old 04-21-2012 | 05:34 PM
Default haha
No, I didn't replace the plugs myself... My skill level is that of a first grader when it comes to cars. But I want to learn. So far I know the names and locations of basic things, I can change my wipers, check my oil, get gas, add windsheild wiper fluid, check tire pressure and add air, add coolant... Um beyond that I'm useless. Good luck, let me know if that really helps!
Old 08-04-2013 | 09:46 AM
Ben Johnson's Avatar
Default Did the problem get resolved?
Lee, did you find a final solution? As a new owner of an '02 Accent with tranny problems, I'm struggling for answers.
Old 08-29-2013 | 07:19 AM
Erichshonda's Avatar
From my past experience I have delt with this code many times. Yes there is a bulletin for this fault but it is useless. I have replaced many transmissions for this fault under warranty. After servo replacement this never repaired a single vehicle. Back in those days I sometimes would replace 2 to 3 transmissions a week. These early model transmissions were a major weak link for these cars.
Merlin Coryell
09-06-2015 05:13 PM
ftasux
05-29-2015 02:17 PM
ccwoil05
12-08-2010 06:49 AM
Bluewaters
01-21-2010 10:43 PM
g3mini
05-22-2008 04:47 PM
