07 Accent entire instrument cluster not working
Old 01-04-2018 | 07:38 PM
Laaman's Avatar
Default 07 Accent entire instrument cluster not working
I'm looking at buying an 07 Accent (hatchback) for what seems to be a pretty good deal. The holdup is that the instrument cluster doesn't work. Does anyone know what kind of problems this thing could have before I go ahead and make the purchase? Thanks.
Old 01-04-2018 | 09:53 PM
avisitor's Avatar
I am thinking that the owner couldn't figure out that problem
So, now the owner wants to sell it
From what I know about cars in general ... (not much)
There is a fuse .. about 10 amps ... that has power when key is in on or start
This is for the warning lights
As for the lights on the dash or instrument cluster
The power comes from a fusible link .. about 30 amps .. through a relay
Control side is the multi-function switch (stalk switch)
There should be a rheostat which controls the brightness
Would check fuses and fuse box
Check for corrosion
1lampman
09-10-2013 07:05 AM
JoshuaBum
09-06-2011 03:57 PM
mookiemoo
02-26-2011 11:00 PM
GdayX3
01-20-2008 03:41 AM
Northwestlawn
11-20-2006 10:08 PM
