1996 front brake rotor
What's the best way to remove the front brake rotor from a 1996 Hyundai Accent? Am I assuming correctly in that in order to remove the hub nut you need to turn it counter clockwise?
Thanks for your help.
www.hmaservice.com has all the service info.
however its very simple.
-jack car up - use jackstands and wheel chocks. be safe.
-remove tire
-remove brake caliper mounting bolts - NOT the slide pins
-caliper slides right off. might have to push/grunt a little but its not bad.
-get some wire or rope and tie the caliper to the spring to avoid letting it hang.
-rotor pulls right off.
-remove tire
word2yamutha
09-03-2015 12:17 AM
akkernight
07-25-2010 07:13 PM
