1996 Hyundai Accent overhearing
When the engine is cold, check the coolant level?
Start engine with radiator cap off
Watch to see if the fans turn on
Turn AC on and see if both fans turn on?
Do you see coolant flowing pass in the radiator ?
No flow could be due to stuck thermostat or failing water pump
If all else is fine then radiator needs to be cleaned and flushed
It could be something else but would need more testing
