1999 hyundai accent
Old 10-23-2009 | 12:35 PM
pro_51492's Avatar
Default 1999 hyundai accent
I just bought a 99 accent and it has a mysterious problem, i bought the car non running then when i got it home it started and i drove it, then it wouldn't start any more. I do not know whats wrong with the car? I'm assuming its the coil pack. Does any one know what it could be?
Old 10-23-2009 | 02:55 PM
james21v's Avatar
i think you should check the battery status first... then think something else... Enjoy!!!
Old 10-29-2009 | 09:15 PM
pro_51492's Avatar
The battery is fine it just keeps cranking, and just found out its getting no spark.
Old 11-02-2009 | 09:52 PM
pro_51492's Avatar
i got he new coil pack and it still will not fire?
Old 11-07-2009 | 06:53 PM
retsam's Avatar
Probably more a crank shaft sensor problem... more commun
Old 11-11-2009 | 04:38 AM
M.D's Avatar
M.D
Cool
I am almost 100% certain it is the crankshaft censor,I had a similar problem and I had it a Hyundai dealer yesterday,It cost me R980,dont know how much it is in youre currency,but it is not to hefty.
Any-one correct me if i'm wrong,the mechanic said it is a little thingy that is situated somewhere near the exhaust manifold.Its got a little plug on the one end and a round censor that fits in somewhere else??
Old 12-03-2009 | 06:09 AM
ernysp76's Avatar
There is a test you can do on the crank position sensor to see if it faulty unfortunately I don't have my book here at the moment. These little things are often the cause on non-starting motors or motors that suddenly cut out. Make sure all the usual suspects are OK such as the ECU being earthed etc.. but would be most likely the CPS needs replacing.
brithepi2k
11-24-2008 01:51 AM
bigdaddy
05-18-2008 12:49 PM
brithepi2k
03-18-2008 11:09 PM
brithepi2k
03-15-2008 12:12 AM
jweidler
04-30-2007 02:51 AM
