2 different parts no for PVC Valve on 1999 Accent
Old 07-21-2009 | 09:06 PM
Rhondas's Avatar
Default 2 different parts no for PVC Valve on 1999 Accent
Pcv valve, accent, dohc
96-02 $11.38
Pcv valve, accent, sohc
96-02 $12.77 Which is the right pcv valve for my car?
problbly one is over head single cam, other is probaly overhead dual cams?
Is there going to really be a difference first of all I never seen a 1999 accent with dual overhead cams, unless the automatic transmission type has that feature ,mine is a single ohc because I replaced the timing belt ,one sprocket,mine is a 5 speed stick shift,but my question is does this mean they make a different spring and ball tension in each PVC valve ,is there really a differnce ? why 2 part numbers and prices ? I always thought you by a fram replacement PVC and that was it for any 4 cylinder car.
Old 07-21-2009 | 10:20 PM
Yes, there are 2 differen't PCV's because there are 2 different engines. One is a 1.5L SOHC (Single OverHead Cam), the other is a 1.5L DOHC (Double OverHead Cam). Use the right part for the right engine.
bhkbhk
04-29-2011 08:55 AM
4jrfox
12-08-2010 11:52 PM
HangingAround
09-10-2009 03:47 PM
gunwaleman
06-29-2009 03:17 PM
thx1971
04-27-2009 02:37 PM
