2 issues i think related, cooling system
I am new to this forum and my daughters car has an issue with the temp gauge showing very low like just getting off the bottom, i just changed the thermostat on the motor and i know the engine is up to temperature. also the electric fan on the radiator starts running a couple of seconds after you start the car and continues to run all the time. Question: are the sensors that drive these two things somehow connected or can the wires somehow be crossed?
oh ya
99 accent gsi
automatic
Thanking you all in advance for your replys
oh ya
99 accent gsi
automatic
RE: 2 issues i think related, cooling system
Question: are the sensors that drive these two things somehow connected?
Yeah i would check to see if there's a slight short in the temp sensor wiring. I've had that happen on vehicals before and had all kinds of temp readings despite the actual temp of the engine
