2002 Accent Manual Transaxle Fluid Change
Old 07-02-2012 | 09:11 AM
ritchep's Avatar
Default 2002 Accent Manual Transaxle Fluid Change
I have a 2002 Accent with 197,000 miles on it. I have had the shop change the transaxle fluid up until this point, but would like to try it myself.
Have any of you changed it on an '02 Accent? Is it a difficult job? Is there a filter I need to change with it?
Thanks for your feedback.
Old 07-02-2012 | 09:40 AM
Just a drain and refill. No filter.
Old 07-02-2012 | 01:45 PM
ritchep's Avatar
Hey Nova, is it a difficult job? I do almost all of the minor maintenance myself right now, so I'm reasonably competent.
Old 07-02-2012 | 02:36 PM
REPLACEMENT OF TRANSAXLE GEAR OIL
Use HP Gear Oil SAE 75W/90 (API-GL-4)
1. With the vehicle parked on a level surface, remove the drain plug and drain the transaxle oil.
2. Replace the gasket with a new one and install the drain plug.
Tightening torque: Drain plug: 30~35 Nm (300~350 kg·cm, 22~25 lb·ft)
3. Add new oil the through the filler plug, filling to the same level as the opening plug.
Transaxle oil total capacity: 2.15 Liters (2.27 U.s.qts., 1.89 lmp.qts.)
Tightening torque: Filler plug:30~35 Nm (300~350 kg·cm, 22~25 lb·ft)
Drain (bolt removed in picture):
Fill (bolt removed in picture):
kennyjohn
02-14-2012 07:22 PM
chuckiesob56
05-31-2011 09:39 PM
v1vrfly
02-14-2011 09:52 AM
atholon
07-15-2010 12:54 PM
whowasthat
08-29-2009 11:06 PM
