2002 hyundai accent timing belt problem.
Please help. I spent hours on end trying to put the spring back on the tensioner. I was replacing the timing belt and tensioner. I took off the old tensioner and was trying to put the new tensioner on. On theright side of the tensioner is the pivot bolt. The left side has a bolt. First you put the spring over top the hole then the metal case inside the spring and then the bolt on top. I can't compress the spring to fit it back around the two metal pieces. Any one who has a 02 accent and has changed the belt and tensioner should have an idea as to what i'm talking about. Any help is greatly appreciated.
2000, 2002, accent, belt, compare, directions, hyundai, kit, photos, prices, replacement, replacing, serpentine, timing, years
