2004 Accent Transmission
2004 Accent Automatic Transmission
Automatic
by the way, the fluid is nearly black, but no signs of metal in the pan. How deep should I go?
Also, it's looking like the whole engine/transmission pack has to come out together. Yes?
Teddybear
Teddybear
What is wrong with Transmission?
no reverse
when up to operating temp., slams into drive(1st)
will not shift to 2nd, except sometimes at high rpm
i do not know the symtems prior to failure except that it "banged" than would not shift. Father-inlaw drove home (15miles) in 1st gear very slow.
I towed it to my place, drove it around up to 30mph, shifted once or twice. still no reverse.
Thanks Dan
Thanks Dan
I think it is toast from what you describe. If you insist on a DIY project, I think I'd buy an already rebuilt tranny and torque convertor. Otherwise, I'd find a good transmission mechanic to do the work for you. The guts of these things are quite complicated and usually require a number of special tools that your average person doesn't have. The HMA Service site (Hyundai Service Website) has instructions regarding removal.
I am going to rebuild the trans. With these symtoms, what would be a likely item(relay, pulse generator, valve, etc.) that would have gone bad? Bands are understood. I'll do a total tare down and clean. (I made the mistake of not getting a diagnostic before I started.)
Thanks, Dan
Thanks, Dan
glassfern53
09-05-2015 03:47 PM
quesadiella
03-30-2015 10:05 PM
JermTheElf
09-07-2010 10:02 PM
04, 2004, accent, accenttransaxle, auto, hyundai, pan, rebuild, rebuilding, rebuilt, removal, torque, tranny, trans, transmision, transmission
