2005 accent factory radio
Old 12-15-2008 | 10:42 AM
iroc's Avatar
Default 2005 accent factory radio
Need to know how to remove it.
What all needs to come apart
thanks in advance
Old 12-15-2008 | 11:59 AM
Default RE: 2005 accent factory radio
2005 > G 1.5 SOHC > Body Electrical System
REMOVAL AND INSTALLATION
1. Disconnect the negative battery terminal.
2. Remove the glove box.
3. Disconnect the 2 heater side control cables under the lower crashpad and one blower side control cable under the glove box.
4. Loosen the screws and remove the center facia panel.
5. Remove the audio mounting screws (4EA) and the audio system.
6. Installation is the reverse of removal.
Old 12-15-2008 | 12:06 PM
iroc's Avatar
wow.
you are the best....
thank you very much
Old 04-11-2010 | 07:29 AM
rokuez's Avatar
thanks for this i got a tape jammed in there!!
any suggestions for what to replace it with ? or maybe if I can get this tape out I can just do it myself!
rlupiv73
01-02-2009 05:38 PM
Integraoligist
12-19-2008 09:23 PM
downunder94
10-03-2008 06:14 PM
sitinon32
05-07-2007 04:27 PM
