2008 Hyundai Accent GS (3dr)
Old 07-21-2008 | 04:53 PM
Default RE: 2008 Hyundai Accent GS (3dr)
ORIGINAL: SHOZ
The trouble I see it is there doesn't seem to be an overdrive in the 5 speed.
5th gear is overdrive:
- 1st = 3.615
- 2nd = 2.053
- 3rd = 1.370
- 4th= 1.031
- 5th = 0.837
- Reverse = 3.583
- Final gear ratio = 4.056
  #12
Old 07-22-2008 | 02:31 AM
SHOZ's Avatar
Then the final drive is too high. There is only 500 rpm difference between 4th and 5th.
But thanks for the numbers.
  #13
Old 07-22-2008 | 08:19 AM
ORIGINAL: SHOZ
You should call Hyundai and let them know their engineers and designers are wrong. Maybe next time they will consult you first.
ORIGINAL: SHOZ
Actually, there is a 669-rpm difference.
60-mph in 4th gear = 3558 rpm
60-mph in 5th gear = 2889 rpm
Remember, this is a small displacement 4-cyl engine with limited torque. You don't want the rpms too low. Those engine make power and are more efficient at higher rpms.
  #14
Old 07-22-2008 | 12:04 PM
SHOZ's Avatar
I tried calling them but they only take calls from you apparently.....
  #15
Old 07-22-2008 | 02:20 PM
ORIGINAL: SHOZ
I forgot about that. I'll call them on your behalf and make sure they take you calls from now on.
  #16
Old 07-22-2008 | 02:25 PM
SHOZ's Avatar
I've thought about calling them. My Festiva had a 1.3L motor with a 5 speed. 4th and 5th were both OD and the car ran great, easily getting 45 mpg. The gear ratios on the Accent's 5 speed transmission are way to close for the most efficient economy. There is plenty of torque multiplication on this car. I didn't buy this car for its quarter mile performance.
  #17
Old 07-22-2008 | 03:08 PM
ORIGINAL: SHOZ
The last Festiva was in 1993 (it was called the Aspire after that). It had a curb weight of 1797-lbs and a 63-hp 1.3L engine rated at 35/42 mpg (source).
The 2008 Accent has a curb weight of 2467-lbs and a 110-hp 1.6L engine rated at 27/32-mpg (source).
The Accent is 670-lbs heavier than the Festiva. That's like driving your Festivia around with three extra 220-lbs guys. I'll bet you wouldn't get 45-mpg in your Festiva with all that extra weight. Plus, the Festiva had a better fuel economy rating to begin with.
  #18
Old 07-22-2008 | 03:16 PM
SHOZ's Avatar
I guess I'll continue with my plan of going to taller tires then.
  #19
Old 07-22-2008 | 03:33 PM
Taller tires will throw your speedo and odometer off. They will both be inaccurate and therefor, you won't know the true mileage.
  #20
Old 07-22-2008 | 03:36 PM
SHOZ's Avatar
I know that. But if the degree of error is known then the actual mileage can be extrapolated.
Whast's the 14" tire width stock?
