2010 Accent Mass Air Flow Sensor
Old 03-28-2012 | 01:05 PM
mfm2010acc's Avatar
Question 2010 Accent Mass Air Flow Sensor
Hi,
I have a 2010 Accent GLS 1.6L. My car sometimes has a hard time starting., its as if the car was flooded. The car turns over then dies. The problem goes away for a while and then returns. I have read on several threads that the Mass Air Flow(MAF) Sensor might need cleaning. I removed the Air Filter Lid and the hose going to the intake valve and I have not located the MAF. Apparently my car has a MAF, on the fuse panel it shows Fuse No. 28, 10A, has having several functions including the Mass Air Flow Sensor.
So, does my car have a Mass Air Flow sensor, and if so, where is it?
Thanks,
mfm2010acc
Old 03-28-2012 | 01:56 PM
No, your engine uses MAP (Manifold Absolute Pressure) sensor, not MAF (Mass Air Flow) sensor. Totally different.
Get the computer scanned for trouble codes.
Old 03-29-2012 | 09:52 AM
mfm2010acc's Avatar
Default Thanks
Thanks for the quick reply, you no doubt saved me a couple of dollars and a great deal of frustration
cheers,
mfm2010acc
Prilly1977
04-10-2017 11:09 PM
Hawqis1
04-05-2014 08:51 PM
MOMO
06-24-2013 04:32 AM
teabear
08-04-2011 01:47 PM
SonataDude
04-03-2009 06:43 PM
Quick Reply: 2010 Accent Mass Air Flow Sensor
