2G (2004) Hyundai Accent GT transmission fluid change
Old 09-07-2010 | 12:21 AM
JermTheElf's Avatar
Banned
Default 2G (2004) Hyundai Accent GT transmission fluid change
Okay so before the flaming can begin, please just answer a few questions for me. I was performing a routine oil change on my girlfriends car, and I decided it'd be a great freakin idea to drain the transmission fluid. So after that mistake, I now have twice the oil, a new oil filter, and no transmission fluid. I have one bottle of castrol multi vehicle import A/T fluid. How many quarts does this car take? I believe I have about 3.5 quarts drained but I just want to make sure. The manual says 6.45...... And I'm going to drain all the oil out, and redo the oil change, but keep the filter. Thank you all for your help, I'm a mitsu guy myself and my oil pan is on the opposite side as hers, messed me up. She has a 2004 accent GT Auto. Thanks so much.
Old 09-07-2010 | 10:11 AM
First, Hyundai automatic transmissions REQUIRE SP-III trans fluid ONLY. Do not use any other type of trans fluid. My suggestion, buy a few quarts from a Hyundai dealer. If you just drained the pan, it only takes about 3 quarts. The 6.45 in the manual is for the entire system. Removing the pan plug does not drain the fluid in the valve body, pump and torque converter.
Old 09-07-2010 | 11:39 AM
zero_gravity's Avatar
Banned
we all contemplate it, but don't go down that tempting road of using the multi-vehicle fluid to get it going for now with the intention of changing it later. its not worth the risk of a blown/damaged transmission!
Old 09-07-2010 | 12:16 PM
JermTheElf's Avatar
Banned
Thank you! I'm sure it couldn't be too much more than $10 a quart I'm assuming. Thanks for the info I will be returning the Castrol A/T fluid.. it does say SP-III compatible on it, but you guys know what you're talking about judging by your dedication to the Hyundai forum. Thanks again guys!
Old 09-07-2010 | 12:32 PM
Why would you think it would cost $10 a quart? Just because it's from a dealership? I paid $5.75 a quart for Hyundai SP-III ATF. How much was that Castrol ATF?
Old 09-07-2010 | 03:26 PM
JermTheElf's Avatar
Banned
I called them and they quoted about $7. From experience with dealership pricing on fluids I was guessing and wasn't too far off. Castrol was $4.25 a quart.
Old 09-07-2010 | 10:02 PM
JermTheElf's Avatar
Banned
Thanks for your help guys, the car runs smoother than ever.
kartoos
11-28-2019 09:46 PM
river123
05-17-2012 11:39 AM
Hacken
04-03-2011 05:50 PM
v1vrfly
02-14-2011 09:52 AM
simibaby
10-22-2006 02:04 AM
