95 Accent/Excel window trouble
My driverside window came out of the cheap little Korean plastic housing and no matter what compound I use the window will not hold in the damn thing. I want to roll down my window without pushing down on it as I roll it down. Does anyone know of an epoxy that will hold. I have tried:
Caulking
JB Weld
Super Glue(I am desperate)
Chimney Sealant
I need suggestions, I am getting pissed off.
Caulking
JB Weld
Chimney Sealant
RE: 95 Accent/Excel window trouble
It is a wierd little setup. There are two plastic pieces that the window sits into. To describe how I will say that the plastic piece looks like a taco shell and the window would be the meat. There was originally an epoxy of some kind that glued the two together that quit on me. If I put a screw in there i would have to drill a hole through the window.
ORIGINAL: Sanguinius
Have you thought about perhaps drilling a hole in the housing and putting a small bolt in it? I'm not sure what it looks like but it might be an idea...
Have you ever tried drilling in safety glass (which all car windows are made of)
I use jb weld on mine and it holds very well you just have to clean it well (with alcohol) and sand the glass a bit (scratch it up) and mix the jb weld weld of course
Andy123
02-02-2015 01:37 AM
pjbjleal
11-02-2011 06:40 AM
dwhite468
01-15-2008 12:41 PM
