'99 Accent Exhaust Manifold
Old 06-02-2009 | 11:37 PM
troyboi's Avatar
Default '99 Accent Exhaust Manifold
I have a cracked exhaust manifold and my mechanic took out the cracked one and tried to replace it with a '98 and it did not fit.
Are the manifolds from the 1999-2002 Accent compatible with each other?
Is it best to find a junk yard and just take one out of there?
Or should I find a welder to repair it?
A new part is over $500 and I know I can find a used one somewhere cheaper... way cheaper. Please help so I know which models to seek to take this part out... Thanks!
Old 06-03-2009 | 06:03 AM
jsinton's Avatar
Banned
Yes, the 1998 manifold is significantly different from the '99. You could get one from the junkyard, but then there's the problems with the CAT too. A lot of times the CAT bolts are all rusted up, or the CAT itself is toast.
The 99 manifolds had this problem with cracking, so I wouldn't get one from the junkyard. The Elantra RD model was only made until 2000, so that means you'd have to find one from '99 or '00. I wouldn't expect the Accent manifold to fit.
I'd buy this manifold + CAT from eBay for around $190:
http://cgi.ebay.com/ebaymotors/2-0-H...spagenameZWDVW
Old 06-03-2009 | 08:31 AM
ken99's Avatar
Elantra cracked manifold recall, may/may not apply.
http://www.hmaservice.com/files/331/...5-01-001-1.pdf
Linda Sheppard
09-06-2023 12:40 PM
aitkel
07-31-2009 09:54 AM
Nirky
01-28-2008 07:44 PM
SpoolinMX6
03-02-2007 01:22 AM
Tiburon100
12-06-2005 06:17 PM
Quick Reply: '99 Accent Exhaust Manifold
