'99 Front Wheel Bearing
Where can I find a good diagram of the front wheel bearings and how to replace them. I have the steering knuckle removed and the hub pressed out. I'm having a problem removing the bearing from the hub and want to know how to remove the bearing from the knuckle. Is this something I can do on my own or will I be taking it into a shop? How much should I expect someone to do the work for me?
It requires a special tool.
1999 > G 1.5 SOHC > Drive Shaft & Axle
BEARING REPLACEMENT
1.
Install the special tools as illustrated.
2.
Remove the hub from the knuckle by turning the special tool.
a.
Be sure to use the special tool.
b.
If the hub and knuckle are disassembled by striking with a hammer, the bearing will be damaged.
3.
Secure the knuckle in a vise.
4.
Remove the brake disc from the hub.
[See large image...]
5.
Remove the outer bearing inner race from the hub using special tools (09532-11000, 09532-11301, 09517-21100).
6.
Remove the oil seal and inner bearing inner race from the knuckle.
7.
Drive out the bearing outer races from the knuckle using the special tools.
If either the outer or inner race needs replacement, they must be replaced as a set.
8.
Apply the specified multipurpose grease to the outside surface of the bearing outer race.
9.
Install the bearing outer race into the knuckle with Special Tools (09500-21000, 09517-21000, 09517-21200).
10.
Install the disc to the hub, and torque to specification.
11.
Apply the specified multipurpose grease to the bearings and inside surface of the hub.
12.
Place the outside bearing inner race into the knuckle.
13.
Drive the oil seal (hub side) into the knuckle with the special tools.
14.
Apply the specified multipurpose grease to the lip of the oil seal and to the surfaces of the oil seal which contact the hub.
15.
Place the inner bearing into the knuckle.
16.
Tighten the hub to the knuckle to 230 Nm (2,350 kg.cm, 167 lb.ft) with the Special Tool (09517-21500).
17.
Rotate the hub to seat the bearing.
18.
Measure the hub bearing starting torque.
19.
If the starting torque is 0 Nm (0 lb.in), measure the hub bearing axial play.
20.
If the hub axial play exceeds the limit while the nut is tightened to 235 Nm (2,350 kg.cm, 167 lb.ft), the bearing, hub and knuckle have not been installed correctly. Repeat the disassembly and assembly procedure.
21.
Remove the special tool.
22.
Apply the specified multipurpose grease to the bearing and to the inside of the knuckle.
23.
Drive the oil seal (drive shaft side) into the knuckle until it contacts the bearing outer race using special tools.
24.
Apply the specified multipurpose grease to the lip of the oil seal.
25.
Install the parts to the torque specifications.
26.
Lower the vehicle to the ground and tighten the knuckle to the lower arm ball joint connecting bolt.
BEARING REPLACEMENT
1.
2.
a.
b.
3.
4.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
16.
17.
18.
19.
20.
21.
22.
23.
24.
25.
26.
