Accent Dash Lights
Old 11-25-2008 | 05:46 PM
rcacs's Avatar
Default Accent Dash Lights
Hi, my daughter bought a used 2001 Accent GSI. The dash lights are so dim that you cant actually see the dials at night. The dimmer switch works just fine, and I removed the cluster to check the bulbs. There are only 2 bulbs (have a green rubbery coating), and they both work just fine. I slipped the rubbers off the bulbs, and that only made a tiny difference.
The car has white gauge faces, and was wondering if that is stock....it would seem that once the black bezel is put back on the cluster, there is no way for light to actually light up the gauges.
Again there is no problem with the bulbs they are actually very bright, the light just doesnt get thru to light up the gauge faces, so I am thinking these are not the stock faces and are not allowing any light thru them.
Anyone had such an issue?
Cheers
Old 11-27-2008 | 02:21 PM
rcacs's Avatar
Default RE: Accent Dash Lights
A bit of an update on this problem:
Once in awhile all of a sudden the dash completely lights up, even though you could tell the bulbs were already on. I bypassed the dimmer switch to eliminate that, but the problem persists. If I start the engine, it seems the lights will come on to the point that you can actually see the instruments nicely. Whilst they are on, there is occassional minor flickering. I have cleaned all plug connections, and even added an additional ground to no avail. After a few minutes, the lights go dim. I dont think there is a real connection to having the engine running, as it does it "less frequently" with the engine off.
I now note that the gauge faces are lit themselves, and these are the lights that are being intermittant. The two bulbs in the back side of the pod are not the problem. I am suspecting the inverter that is behind the gauges (inside the pod).
I dont have a Hyundai dealer closeby, so it will be a day or two before I can pick up an inverter and try that.
Cheers,
Rick in Canada
Old 12-19-2008 | 01:26 PM
rcacs's Avatar
Hyundai wanted a 160 clams for a dash light invertor...geez
Picked up a complete instrument panel on EBay for 27 bucks.
Works likea charm.
cheers
Old 12-21-2008 | 12:44 AM
cliffjumper's Avatar
right on!
psychodoodbrij92
03-28-2019 12:54 PM
ronnieoverholser
05-12-2013 09:57 PM
Verminator
09-14-2011 02:03 AM
DOH
01-20-2009 08:47 PM
Stujak
04-07-2008 07:58 AM
