accent engine management light
Uhhh,,,,,, YES !!!
MIL illuminated, P-0133 Ox Slow Response, Bank 1 Sensor 1 (pre-cat / upstream), and the exhaust pipe is cracked right at the accordion (flex section) and noisey...
Hyundai had to issue a service bulletin back in 2006 for the issue, too many people replacing Ox sensor (upstream),, only to have light back on after system logic determines the sensor is slow to respond..
There is program for Ox Logic, #52, for a 0130 issue, but update it anyway. There is also a trans update for VSS Noise (pulse generator), #18 or #19, I would have to go find it...
TSB info :
Add (2) gaskets and (4) nuts to assemble each flange
TSB info :
DESCRIPTION:
When diagnosing Code P0133 (Front Oxygen Sensor - Slow Response) on a 2000 -
2002 model year Accent, verify the integrity of the front exhaust pipe between the front
and rear oxygen sensors. A leak in the pipe can affect the ECM diagnostic logic for the
front oxygen sensor.2002 model year Accent, verify the integrity of the front exhaust pipe between the front
Vehicle -------------------------------Part Number ------Description
2000-2002 Accent; 1.5L engine 28610-25000 -----PIPE-EXHAUST FR
2000-2002 Accent; 1.6L engine 28610-25700 ------PIPE-EXHAUST FR2000-2002 Accent; 1.5L engine 28610-25000 -----PIPE-EXHAUST FR
seane77
10-23-2006 04:50 PM
