Accent timming belt
Me thinks I have poted pics here in the Accent forum a couple times..
Nothing major about Accent belt,,
Flip drive belts off
Remove mount ear between engine to frame
Remove water pump pulley
Knock the crank pulley bolt loose
Remove upper cover
Turn crank pulley to "T", verify hole in cam and pin is up
Look through hole in pulley, see line
Remove crank pulley and tin
Remove timing belt, install new belt, drop tensioner to snug belt.
Verify marks are all in place and correct
Finish assemble
Remove upper cover
Finish assemble
