Aircon Clutch Problem?
Hi,
I have a 2004 Accent that give a chirp or squeak when the aircon comes on. It also seems to engaged with a bit of a jerk. The dealers fix was to tighten the belt which had no effect. Any ideas?
Thanks.
Thanks.
RE: Aircon Clutch Problem?
if the dealer has tightened the belts it probably means the a/c clutch is starting to fail or slip they are easy enough to change as they can be unbolted from the a/c compressor. go back to the dealer and have a word!
speeder
03-09-2008 07:05 PM
