Am I being taken for a ride?
My 2005 Accent with 34k miles was getting a "bump stop" and shifting poorly when downshifting overall. This thunk also happens at speed and can get violent when accelerating uphill where it first releases, revs really high, and slams into gear. This doesn't happen all the time but the Hyundai dealer was able to reproduce the problem. Yes this is an automatic transmission.
I took it Darlings Hyundai is Augusta since it is still under warranty and they just called me up saying I need to have the transmission fluid changed for $75. Then a little later they called again and said it involved a filter and was more involved. They say it is general maintenance under the extreme weather service schedule which says every 30k (not the regular schedule which is must less frequent). They said no state in the US qualifies for the regular schedule . . . . I know the winters in Maine are tough but am I being taken for a ride here with this $200 maintenance hit that might or might not fix the issue?
RE: Am I being taken for a ride?
Yep, the automatic trans fluid needs replacement every 30K miles to keep the warranty. I've done it on all my Hyundais.
I'd have the service done and hope it solves your problem because if the trans is bad and they find it's because the fluid wasn't changed at 30K, they might void the warranty on the trans. Good Luck.
kwitcherbytchn
11-12-2009 01:13 AM
Akstud1983
11-04-2007 01:59 AM
