Any difference?
Old 07-05-2009 | 12:46 AM
bigrob's Avatar
Default Any difference?
Is there any difference in the base Accent that I own, and the SE mechanically? I mean I know all the options and stuff, I mean are the engines, transmissions, suspensions all the same, or does the SE have some advantageous items?
Old 07-05-2009 | 08:21 AM
Yes, the base comes with smaller steel wheels while the SE has larger aluminum wheels with lower aspect ratio tires. It also has a sports tuned suspension (basically different springs and possibly different struts and sway bars).
Old 07-05-2009 | 09:26 AM
bigrob's Avatar
Yes, the base comes with smaller steel wheels whiel teh SE has larger aluminum wheels with lower aspect ratio tires. It also has a sports tuned suspension (basically different springs and possibly different struts and sway bars).
Thanks Nova. Thats what I was thinking. I just put a set of the OEM 16" wheels on MY car. Much better look!!
Old 07-05-2009 | 03:11 PM
Yep, larger factory wheels make a big difference. That's why I added the 18" wheels from a Veracruz to my Tucson.
Old 07-06-2009 | 12:34 PM
bigrob's Avatar
They look sharp! I believe 4 wheel discs are on the SE as well.
Old 07-06-2009 | 01:44 PM
Nope, the SE has rear drums just like the base. However, the SE does have ABS.
Old 07-06-2009 | 04:55 PM
bigrob's Avatar
Wow! No 4 wheel disc? Thats cheap! Oh well
Old 07-06-2009 | 05:10 PM
Yes but remember the Accent is an economy car and the lowest priced Hyundai available in the states. Rear drums are cheaper than discs.
Old 07-07-2009 | 08:11 AM
bigrob's Avatar
That's true, I just figured the SE model, being a good deal more $, would have gone that route and put the discs at all corners.
jbrink
07-04-2014 01:45 AM
Siddharth Chand
04-18-2012 03:28 PM
GrayKnight
01-16-2009 10:09 PM
noobliterator
02-08-2008 11:23 AM
frozeh2o
04-28-2006 04:59 PM
