Anyone Try The B&M Short Shifter Kit?
Old 01-24-2011 | 08:52 AM
Originally Posted by pete66
Does this shifter let you convert a automatic to a stick?
Seriously? Is this a real question? If it is, please go take a class on auto mechanics.
  #12
Old 01-25-2011 | 01:31 AM
hondahirny's Avatar
I was debating on whether to answer the question seriously or not. I think some cross-drilled brake lines might be in order...
  #13
Old 01-25-2011 | 09:59 AM
Here you go if you need them:
http://kalecoauto.com/index.php?main...&products_id=1
Review:
http://kalecoauto.com/index.php?main...nmv1a44dduaqc6
  #14
Old 01-26-2011 | 11:14 PM
hondahirny's Avatar
I'm thinking the lowering kit would be sweeeeet!
BTW, i did finally try the B & M shifter in my Accent. For me, the increase in shift effort wasn't worth the reduced throw. I went back to the stock shifter and the B & M is on Ebay. Oh well... worth a shot...
  #15
Old 01-27-2011 | 07:15 PM
Realto's Avatar
Default B&M shifter
I bought the B&M shifter online and installed it shortly after I got my 08 Accent. I would definately recommend it! As you know, the standard shifter is sloppy and the reverse clunky. The new shifter replaces the standard plastic shift ball with a smooth machined aluminum ball and shift rod. Their is a 'box' above the shift ball, with a different type lockout tab for reverse. The result is you get more weighted, shorter shifts, and the reverse is closer and not clunky. You'll be real happy with the difference. I also bought the leather shift ****, much nicer than stock. It's an easy install, the only tricky part is you have to cut one push nut (which wasn't designed to be removed), with a dremmel tool. Cheers
  #16
Old 01-28-2011 | 02:35 AM
hondahirny's Avatar
Thanks for the reply. Nice to hear about your experience. In my case, i didn't like this shifter. Seems i'm the only one
  #17
Old 01-29-2011 | 07:17 PM
austex04's Avatar
I think I will pass on the shifter kit, I can live with the stock one as-is. If only they had a clutch kit, as that's the worst part of the car, everything else they got right.
chrisspamm
06-27-2012 08:54 PM
Annarella
09-07-2006 04:08 AM
tenick
03-13-2006 12:16 AM
silentneko
06-06-2005 04:59 PM
