Auto trans problem?
Old 09-01-2008 | 04:39 PM
tractorboy's Avatar
Default Auto trans problem?
2008 Accent GS Auto trans
Date Purchased: 8-19-08
Odometer Miles: 434
The transmission shifts very smoothly going from 1st gear to 2nd to 3rd to 4th. I think there is, however, a problem with the transmission going into 1st gear that I have noticed during the last 100 miles or so.Fluid level is ok.
After backing in reverse gear, then stopping, then moving the shift lever into the drive position, the transmission will delay going into 1st gear and when it goes into 1st gear it will do so with a jolt and a thud. Some of the time the accelerator pedal must be pressed gently to increase engine rpm slightly above idle to get the transmission to go into 1st gear.
The transmission does the above more severely when the engine and transmission are cold, but it also does it after the vehicle is at operating temperature, just less severely.
Do I need totake the car in to have this problem looked at by the service department?
Old 09-01-2008 | 09:08 PM
Default RE: Auto trans problem?
Take it back to the dealer and let them deal with it. That's what the warranty is for.
Old 09-07-2008 | 09:47 AM
bumbleberry's Avatar
My 02 Accent sometimes used to do that never figuered it out.
Old 09-17-2008 | 01:35 PM
madindian1's Avatar
07 08 normal.
Old 09-22-2008 | 01:48 PM
crmccar1's Avatar
Default p1529,p0732,p0734
Well just purchase an 02 Huundai Accent and it drives fine but the cel came on and these three codes were showing. The shop have not being able to figure it out as yet. His calling a colleage that has more experience in these car than him. Any suggestions?
Old 09-22-2008 | 02:15 PM
Default RE: p1529,p0732,p0734
What are the 3 codes?
Old 09-23-2008 | 10:17 AM
deserttaxguy's Avatar
We just got an 08 Accent that has that same "lag" when shifting from reverse. We have less than 2,000 miles on the car.
I'm not noticing any clunking or other symptoms of a problem yet. The lack of friction going from reverse to first may be
part of their plan to increase mpg. We'll see how it goes. I'm not worried about it yet. Its just kind of annoying at this point,
especially on a hill when you literally roll backwards waiting for the forward gear to engage!
Old 10-27-2008 | 01:35 PM
clintmeister's Avatar
I got a 2008 and it does the same thing. So far no problems. I even got a tow package (u-haul) on it. I would advise a trans. cooler install. I have been testing the kind from street rods. They are extruded alum. with fins from the inside to the outside. I had mine mounted in front of the radiator for full air flow. I would also advise the "2 pass" style of cooler. I like these style for their durability and they will still work if they got junk on them too. If ya don't trust the local dealer mechanics go to a specialist (auto. trans) and have them do a diagostic check.
cstephen
10-08-2007 11:43 AM
dennis041948
03-27-2007 01:41 AM
marcfr
09-20-2006 05:29 AM
Brant
11-01-2005 10:53 PM
car nut
10-24-2005 06:35 AM
