Automatic Trans Problem
Old 11-17-2008 | 11:18 AM
nadel's Avatar
Default Automatic Trans Problem
Hello, My accent gs 2001 sometimes when is running and the gas is not being press (80Km/h +) the trans start to shift gears up and down after that the car stop getting the overdrive even if you press all the gas, and after completly stop the car when you press the gas the car start to run very slow u even have to shift from D to 2 in order to the car star quicker. The car have to be tourned off and on again for this to stop i bealive it could be a sensor but wich one?. regards.
Old 11-17-2008 | 08:30 PM
jsinton's Avatar
Banned
Default RE: Automatic Trans Problem
Sounds like you need to get a ODB II code reading and see if there is any trouble codes. Many things can cause the problems you describe.
Old 11-19-2008 | 10:10 AM
retsam's Avatar
Yep start with the scanner, It will probably give you Pulse Generator A or B (PGA/PGB)
Most of the time, it's the connector problem, it under the battery box and get very dirty.
Solution: Clean well the connector and spray some contact cleaner and you will see, no more problem.
Regards,
Jonathan Lévesque
Old 11-19-2008 | 03:27 PM
nadel's Avatar
Thanks i will clean the connectors and scan my car, this Pulse Generator(PGA/PGB) have something to do with the overdrive problem i mentioned?
pcastellano
10-26-2010 08:15 PM
atcovan
04-06-2008 05:49 PM
sanjayags
11-01-2007 08:56 PM
josephfpu
06-11-2007 02:01 PM
