Bad oil leak
Old 11-15-2019 | 03:37 PM
Suzanne Smith's Avatar
Default Bad oil leak
I am not a mechanic but trying to figure out my pdoblem my 05 accent is pouring oil out when driving leaves a trail . my fruend replaced the valve cover gasket and the problem vot worse i dont have alot of mo ey or time but need some poszible explanations for what this could be
Old 11-15-2019 | 04:42 PM
I hope you are keeping tabs on the oil level in your vehicle's engine. If allowed to go down too low , $$$$ engine or internal parts.
There are several places where oil can leak out and the trick is to make sure the real cause is found and corrected.
You might ask your friend how he determined the leak was coming from the valve cover., which could be accurate, but evidentially the real cause was not repaired.
Sometimes it can be a major job like oil pan gaskets or it could be something small like an oil pressure sending unit. If you can, consider having someone else look it over and make sure it is engine oil and not some other lubricant.
Old 11-15-2019 | 11:38 PM
avisitor's Avatar
Do a visual inspection of the valve cover
Look at the place where the valve cover and the valve head meet
Can you see oil trail?
Place cardboard under vehicle and look at the spot where it is coming down
Follow trail of oil to source if you can
stokelife
11-24-2019 06:16 AM
Jrwildberry
10-21-2019 07:03 PM
pc29
04-04-2012 03:34 PM
dafaceman
07-02-2011 02:07 AM
anonymouse
05-10-2010 01:32 PM
Quick Reply: Bad oil leak
