Brake sensor problem
Old 06-17-2006 | 08:16 PM
sfast's Avatar
Default Brake sensor problem
It seems like my brake sensor has malfunctioned on my 03 Accent. It is like I have my foot on the brake all of the time. So the brake lights stay on all of the time. Even when the car is parked. This of course leads to a dead battery. I was able to find the fuse for the brake lights. So for now I have no brake lights at all but at least I don't have to deal with getting a jump every day.
Does anyone know how to fix this problem? I was hoping someone would know because I hardly have time to take it down to a dealership right now.
Old 08-07-2010 | 01:38 PM
larry l's Avatar
There's could be more than the switch at play here. May be a more simple fix. Pulling up on the pedal will not show for sure if its the switch, since a good switch still cannot make contact if the plastic stop is missing. I had the same problem and found that the plastic stop that is on the brake lever had deteroriated and was missing - found pieces in the carpet. It took less than a minute to replace and only cost $0.91.
The stop is about 1" diameter and 1/8" thick with a smaller diameter that pops into the hole on the brake pedal and makes contact with the switch.
Old 08-07-2010 | 01:56 PM
This thread is over 4 years old.
dwalker50
02-19-2024 07:49 PM
mtbrain3343
05-21-2012 03:30 PM
Log2
03-01-2012 10:52 PM
Rhanck
09-03-2011 08:41 PM
dwalker50
01-16-2011 06:09 PM
