Brake shoes
Old 01-01-2009 | 12:40 PM
TRGBassGuy's Avatar
Default Brake shoes
First of all Hey to everyone!
I have an 03 Accent I need to replace the shoes in but the set up is different than what I have seen before. I checked auto stores for a repair manual and found nothing....same with the internet. Is there anyone who knows how to remove/replace the shoes or have a website or something that does?
Old 01-01-2009 | 12:57 PM
Default RE: Brake shoes
REMOVAL
1. Release the parking brake.
2. After removing the wheel, remove the brake drum.
NOTE:
When removing the brake drum, remove the screw.
3. Remove the adjuster spring and adjuster lever.
4. Remove the cup washer, shoe hold down spring, shoe hold down pin.
5. Move the shoe and remove the shoe adjuster.
6. Remove the lower shoe spring and upper shoe spring. Disconnect the parking cable from the operating lever.
INSTALLTION
1. Apply the specified grease to the locations indicated in the illustration and to each component.
A. Shoe and backing plate contact surfaces.
B. Shoe and anchor plate contact surfaces.
Recommended grease:
Multipurpose grease SAE J310, NLGI No.2
2. Connect the operating lever to the parking cable.
3. Install the shoe hold-down pin.
4. Install the shoe adjuster and assemble the return spring.
5. Assemble the adjuster lever and adjuster spring.
6. Assemble the drum and pull the parking brake lever to full stroke several times.
CAUTION:
Be sure that the inside surface of drum is not contaminated by grease or other materials.
Old 01-01-2009 | 02:07 PM
ken99's Avatar
The schematics NovaResource shared with you came from:
http://www.hmaservice.com/
Registration is free. Requires the use of Microsoft IE and you have to download some required viewers.
Rhanck
09-03-2011 08:41 PM
ken99
11-12-2010 08:38 AM
tub
03-27-2010 02:52 PM
tsh_98103
08-04-2009 08:40 AM
righty
07-05-2008 04:14 PM
