CamPositionSensor (HALL SENDER) !!!HELP!!!
Old 08-10-2008 | 11:59 AM
20vQC's Avatar
Default CamPositionSensor (HALL SENDER) !!!HELP!!!
Hello mates. I'm from Italy. I have a problem using a hyundai accent cam hall sensor on my engine setup, and I can't find any wiring diagram of this Accent on the web! I've realized if someone of you can help me as soon as possible and tell me which pin of the 3-pin plug that goes to the sensor is the 5V, the signal and ground. I hope to receive a little hand by you!!!
Thank you in advance,
Fabio G.
Old 09-04-2008 | 11:56 AM
SHOZ's Avatar
Default RE: CamPositionSensor (HALL SENDER) !!!HELP!!!
Should be pretty easy to back probe the connector. Or disconnect the connector and turn on the key then look for 5V. The ground would be the shield and an ohm meter would show little resistance between it and the neg terminal on the battery.
bobsod
07-14-2006 01:00 PM
