Can't get to back breaklight or liscence plate bulb do i need to take my car into the dealership to
Can't get to back breaklight or liscence plate bulb do i need to take my car into the dealership to get these bulbs replaced?
I just got a fix it ticket in california because one of my break lights was out. When I took my Hyundia Accent to pep boys they couldn't easily replace the light.
Do I need to take my Hyundia Accent 07 into the dealership to have them replace the back breaklight? I also need one of the liscence plate bulbs replaced as well.
Have any of you guys ever fought a fix it ticket? I plan on fighting this in court.
RE: Can't get to back breaklight or liscence plate bulb do i need to take my car into the dealership
Tail Light Fixture:
REPLACEMENT
1.Disconnect the negative (-) battery terminal.[/align]
2.Loose the nuts holding the rear combination lamp then disconnect the 6P connector then remove the rear combination lamp.[/align]
3.Installation is the reverse of removal.[/align]
License Light Fixture:
REPLACEMENT
2.Detach the license lamp lens (A) from the trunk lid panel with a flat-tip screwdriver.[/align]
3.Replace the bulb.[/align]
4.Installation is the reverse of removal.[/align]
