cat & flex pipe 2000 3dr
RE: cat & flex pipe 2000 3dr
I don't understand why you need a catalytic converter if the flex pipe is bad. As you can see by the diagram below, the catalytic converter is a separate piece from the flex pipe. The first pipe in the muffler diagram is where the flex pipe is. Do a search of "universal flex pipe" on eBay, and you will see that you can buy a universal one for cheap. It's a matter of cutting the old pipe where the flex pipe is, and clamping the new flex pipe to the existing pipe.
2000 > G 1.6 DOHC > Engine Mechanical System COMPONENTS [/align] findme('); findme('); findme('); 2000 > G 1.6 DOHC > Engine Mechanical System COMPONENTS
