crankshaft sprocket removal?
I'm still in the process of replacing my timing belt and tensioner. I figured, if i take off the crankshaft sprocket I will have room to pry the tensioner spring back on. However, I'm not positive on how to remove the crankshaft sprocket. Should I use a puller? I don't see a bolt on the end. Some sort of ring with or key shaped piece.
RE: crankshaft sprocket removal?
Hello ShawnBoy,
Geez you did get a lot of problem...
It is true I have never replace yet a Timing belt tensionner.
But I have replace 3 timing belt.
My first one on a ford escort96
second on my sister accent 2002 1.5L
third on my accent 2001 1.6L
They where all easy work and I am not a mecanic.
If you install your tensionner correctly your belt should slide in easy
(tensionner compress)
Have fun,
Have fun,
zainecurtis
04-05-2013 03:34 AM
