Defective Horn
Defective Horn
I have a UK 1995 Accent Coupe. The horn does not work properly, When I press the the horn it either does not work at all, works but not very well (it is low then high etc) or it works fine.
Where is the horn located so I can replace the horn sounder to see if this clears the problem, or check for loose a connection?
Or if you have any other suggestions as to the casue of the problem?
I agree, test the horn first. Here's how to remove it:
1. Disconnect the negative cable from the battery.
2. Remove the left turn signal lamp.
3. Remove the left head lamp and the horn attaching bolt.
4. Disconnect the horn connector and remove the horn.
The horn works intermittently so I know the problem is with the horn. Thanks for the pix NovaResource. You know the saying. A good pix is worth 1000 words. I would not have thought to remove the headlight. I don't consider it good Engineering to stick a part in such an awkward place. I have noticed that these horns seem to be a common failure item. Another brilliant design feature.
jnezon@hotmail.com
08-13-2007 10:53 AM
