Gauge Lights
Old 10-13-2013 | 03:10 PM
CrazedFan's Avatar
Lightbulb Gauge Lights
Hey guys got another question here! Changing out the stock lights in my 05 Accent gauge cluster from the white bulbs to red LED lights. Taking out the entire gauge cluster was no problem at all: unscrew the two screws at the top of the trim, pull the trim out starting from the bottom clips, unscrew the 4 screws keeping the whole thing in place and carefully pull it out making sure not to screw up the wiring. Flip it over and there you go you've got the 4 bulbs that light up the entire cluster that pop right out with a quarter turn. Probelm is I have no idea what size/type these bulbs are and what LEDs can be used to directly replace them. Anyone know here? Thank you!
Edit: I have found the ones finally guys! I will be ordering them soon and will repost when I know for sure that they are the correct bulbs.
Automotive Led Light 509T / B8.5D Twist Fit Red Led Dash Bulb [CA-509T1L-R] - $0.99 : Led Strips Hero-ledstore.com
idahotiburon
09-13-2007 10:55 PM
ehar350L
10-13-2006 02:21 AM
drummerfromhell
05-29-2006 01:25 AM
hbtdawgs
02-09-2006 09:59 PM
tAke_0ner
12-08-2005 07:54 PM
