Grinding noise from front passanger tire
Hi All,
I have a strong feeling I have a wheel bearing that is out, however I wanted to confirm with someone who likly knows more than myself.
I noticed a week back that when I turn right (even ever so slightly) that the front passanger wheel makes a grinding noise on my '03 Accent. The faster I go, it tends to get higher pitched, however still very noticable. The only reason I question as to wether or not it is the wheel bearing is because if I turn left (so the pressure is on that wheel) then I don't hear the sound at all, only when I am turning right do I hear the sound.
Just wondering if this is the bearing, and if so what would be the cost to replace this? If its not the bearing what might it be?
Thanks!
Thanks!
Hello,
I have just done my front driver bearing on my 2001 accent.
The funny part it was not grinding... but the wheels wobble a lot !
If you jack your supected wheel, just try to shake it from left to right and up to down.
And if it wobble, shake... you need a new bearing
If you are not sure..., just jack a normal wheel and compare...
Good luck!
JL
Good luck!
JL
millersmm76
02-28-2008 10:35 AM
