Grounding wire.
Old 11-03-2005 | 12:10 PM
Nauticus's Avatar
Default Grounding wire.
Has anyone installed an upgraded engine bay grounding kit? Like using 8ga/4ga wire to ground the motor and trans to the ground and replacing the battery ground wires?
I have seen this advertised and don't really know if what they claim about high speed/idle stabilization and sound system performance is worth the time. Any thoughts about this?
Old 11-03-2005 | 12:53 PM
poacher's Avatar
Default RE: Grounding wire.
It does make a difference, but not a big one performance wise. By the way of sound systems on the other hand, it makes a phenominal difference because you have cleaner better balanced power. So depending on what your looking for the choice is up to you.
Old 11-03-2005 | 01:45 PM
Brant's Avatar
Nauticus,
Poachers right on this one!!! Huge difference pertaining to the sound system. Performance wise, you might get quicker starts in the cold but, other then that it's a personnal prefrence. I'm doin' that in the spring, upgrading the plugs & wires.
Have fun,
Brant
Old 11-03-2005 | 03:42 PM
poacher's Avatar
Brant,
If you are going to upgrade your plugs and wires might I also suggest that you pick up an ignition coil as well. MSD is one of the best companies around for that, check it out.
Old 11-03-2005 | 08:57 PM
Brant's Avatar
Hey Poach,
Thanks fer the tip. That never crossed my mind but, I will do so!! Thanks again!!
Brant
Old 11-04-2005 | 12:23 PM
poacher's Avatar
No problem Brant. If you can get a hold of that ignition coil then you will see an upgrade in performance.
Old 11-14-2005 | 12:10 AM
Nauticus's Avatar
Is there someplace out there that has a plug wire kit for the 1.6l? Or is it just finding wires that are the right length? I have been looking around and haven't found anything.
Old 11-14-2005 | 10:57 PM
poacher's Avatar
Nauticus,
I too have been looking for enhanced wires with no luck at local dealers. I would suggest looking at Nology they have a wide selection from what I hear. That is where I am going to look next.
Old 11-15-2005 | 08:46 PM
Brant's Avatar
Gentleman,
For larger type wires theres not much out there for us however, I did custom wires for my wife's Wrangler. They were super easy to do. I think I'm gonna wind up doin' the same for the Hyundai if I decide to upgrade the wires.
Brant
Old 11-15-2005 | 10:02 PM
poacher's Avatar
that sounds interesting. How exactly did you manage to do that?
Quick Reply: Grounding wire.
