Grounding wire.
#11
RE: Grounding wire.
Poach,
For a Hyundai there may be some difference, for the Jeep...just cut to length, clamp, boot-it and install it. Just that simple.
I was so freaked out thinkin' bout' it but, once I got into it I was amazed just how simple the procedure was.
Brant
Brant
#14
RE: Grounding wire.
I think I will check with nology, and if no luck there I will look into some 8mm silicone wires. Making a set doesn't seem to scare me at this point. Maybe with the cutters in my hand that will be different!!!
What about the coil? I know the car has two seperate coil packs. Previous experience with saturns says that may not be possible(the two packs on a saturn both mount to a control module). Is it really as simple as removing the old one and replacing it with an aftermarket set of coil?
askem
02-26-2006 12:52 PM
