Headlight bulb replacement
My son has a 2002 Accent with a burned out headlight bulb. The owner's manual says to remove the power cable first, but we can't seem to release it. Is there a clip holding it on that we haven't found. He took it to a local repair place, and they couldn't find one either, so I guess it is not just us.
Thanks,
Jim
Thanks,
Jim
RE: Headlight bulb replacement
Jim,
we have a 1998 Accent and ours just has a little clip that you depress and the wires unplug from the back of the bulb. Then you turn this little ring that's about 2 inches in diameter and it comes off, and then you can take the bulb out. Although, it is a little tight in there, especially on the battery side of the car. However, I don't what your son's looks like, but our bulb is almost round at the back with a flat side where the clip locks onto it when you plug it back in. Being it's a 2002 it may be a little different than ours though. Hope this helps...
milli
milli
REMOVAL AND INSTALLATION
1.Disconnect the negative(-) battery terminal.[/align]
2.Remove the head lamp mounting bolts (2EA), then disconnect the lamp connectors.[/align]
3.Installation is the reverse of removal.[/align]
