Hyundai Alternator
Old 08-21-2007 | 01:35 AM
tinkapark's Avatar
Default Hyundai Alternator
Hello All,
My alternator died in my 2000 Hyundai Accent, so I took on the project of replacing it myself. I have it installed fine, but the only problem is I had to remove the mounting arm/bracket that holds the alternator in place. There are a few pieces and I'm not sure how to put it back together, and how to screw it back into the frame. There is the curved piece, and a small suqare piece that has holes in it wherebolts pass through. Could someone take a picture of this bracket/arm so I can have a guide as how to put it back together?
Old 08-21-2007 | 09:01 AM
Doohickie's Avatar
Default RE: Hyundai Alternator
Maybe this will help:
GENERATOR[/align]
COMPONENTS[/align][/align][/align]
REMOVAL[/align]
Disconnect the negative terminal from the battery and disconnect the radiator fan connector and condenser fan connector. [/ol]
[/align][/align]
Remove the radiator mounting bolts [/ol]
[/align][/align]
Loosen the belt tension adjusting bolt and remove the mounting bolt. Then, raise the vehicle. [/ol]
[/align][/align]
Disconnect the generator connector and remove the B+ terminal cable. [/ol]
[/align][/align]
Remove the belt and detach the generator mounting bolt and nut. Then, remove the generator assembly while raising the radiator. [/ol]
LiaStar
08-25-2014 09:11 AM
Shenyang Jindehui
12-13-2013 02:14 AM
pbuzz3323
12-29-2007 11:02 PM
rebel0375
12-06-2006 02:33 PM
reign_man
01-30-2006 06:28 PM
