Hyundai wiper problems
based on the wiring diagram in the ETM i would check ground G06. this is in the right kick panel on the inside by the passenger door. i attached a photo. the park switch shares a ground with the multifunction switch. if that ground is loose it may be back feeding into the multifunction switch, because electricity will choose the path of least resistance. let me know how you make out with this. good luck
yms1975
12-11-2010 02:14 AM
