I'm still working on this lousy timing belt.
One problem after another. I was better of taking it to a mechanic. Now my problem is that there is not enough room to put back the water pump pulleys. There is enough space for the first pulley. HOwever, the smaller on won't fit back on. Let alone enough room to get my wrench in to screw on the bolts.
RE: I'm still working on this lousy timing belt.
I took off the engine mount. But inorder for me to get it back on I would have to raise it alot. I don't think it will raise up that high. Something must of happened because I know I didn't take the motor mount off when I was removing the pulley. As far as I can remember I had enough room to fit the wrench into the pulley to remove the screws. THis is kinda weird to me. I can't figure out what happened.
