leak? smoke?
Old 12-01-2005 | 12:08 AM
cslsxpistol's Avatar
Default leak? smoke?
by my valve cover theyres something leakinga little and it smokes for a while i was just wondering what it is?
Old 12-04-2005 | 10:20 AM
Brant's Avatar
Default RE: leak? smoke?
Sounds as though your valve cover may be starting to develope a leak. I would guess it's oil your seeing seeping out.
Good Luck,
Brant
Old 12-04-2005 | 07:07 PM
how do i fix that?
Old 12-06-2005 | 01:53 PM
Brant's Avatar
You'd have to remove the valve cover and replace the gasket between the valve cover & the head.
Not too difficult to do, just take your time, get a repair manual from the library or auto parts store.
Read up and again just take your time. Sometimes you'd be surprised just how simple a procedure
is. Good Luck,
Brant
Old 12-09-2005 | 12:34 PM
poacher's Avatar
Sarge is right your valve pan gasket is shot, same thing happened to mine. It is a simple fix, very cheap. Just unbolt the pan and lift off the gasket. Put the new one on and tighten the pan back down.
Old 12-09-2005 | 01:44 PM
Nauticus's Avatar
The valve cover gasket is probably the easiest gasket to replace on the engine. A few bolts and that's it. Good luck and happy wrenching.
saiofa666
10-21-2010 01:56 AM
jbragg923Justin
11-14-2007 09:47 AM
mwiltse
10-12-2007 10:46 AM
Davex
09-28-2007 10:42 PM
saiofa666
02-21-2006 10:48 PM
