MAF sensor connector
Old 06-02-2006 | 12:39 PM
Robinsontc's Avatar
Default MAF sensor connector
Accent 2000 1.5L SOHC
There is a 5 wire connector/assembly going to the MAF sensor. What is the trick or procedure to disconnect this connector -- it does not want to disengage from the MAF assembly.
Any help will be appreciated.
TommyR
Old 06-04-2006 | 06:18 PM
hyundai tech's Avatar
Default RE: MAF sensor connector
Remove the metal clip using a pic and it will unplug.
Old 06-05-2006 | 11:31 AM
Robinsontc's Avatar
ORIGINAL: hyundai tech
ok -- sounds good. Thanks for the tip!
TommyR
p.s. Have you ever successfully cleaned the MAF sensor?
Also, if the MAF acts up, does the computer have a 'soft-fail' mode for this sensor if you un plut it and try to run the car?
Thanks again.
Old 06-16-2006 | 07:32 PM
kevincs's Avatar
Hey Tommy,
I may be a bit late, but if you read my post (kevincs) you may get some insight into cleaning the MAF sensor. I'm having a fuel consumption problem, and i've read that the MAF sensor may have a big part to play. I hope it works out for you, but if you havent cleaned the sensor yet maybe you can wait to see if anybody answers my post b4 you begin.
kiwirocks
07-02-2011 12:48 PM
dunkyd
02-17-2011 05:42 AM
coolguy100
01-02-2011 04:50 PM
MaxHen
07-29-2009 09:22 PM
kevincs
06-16-2006 07:25 PM
Quick Reply: MAF sensor connector
