Need help
Need help
I have a 07 accent 1.6L and I'm replacing the timing belt. I rotated crank shaft to tdc but can't get the valves at tdc. Should I get the valves at tdc then take the belt off and then adjust the crank to tdc or visa versa?
No, keep the timing belt on until you have both the crank shaft and cams at top dead center.
You have an interference engine. Potential danger. Don't be looking at the valves when you need to look at the cams gears.
This means the valves and pistons will hit each other if the timing is not correct.
There should be timing marks on them and they will align when the revolutions are right.
For every one revolution of the crank shaft the cams will turn half a revolution.
If you turn the crank shaft to top dead center and the cams are not lined up properly
Then you need to make the crankshaft turn another full revolution.
Watch your timing marks.
If you need visual then check out youtube videos on changing timing belts.
How are you checking the cam timing marks?
Take a look at this video and at about 5 minutes into the video it show what to look for and where to look for it.
If still un sure then look at all the parts of this video to see what is required to do this job.
https://www.youtube.com/watch?v=bjPvICQPcsM
