Need Help Diagnosing - Fuel Pump issues?
Old 01-10-2015 | 06:50 PM
tjjolle's Avatar
Default Need Help Diagnosing - Fuel Pump issues?
Greetings,
Any help will be much appreciated.
2010 Hyundai Accent
My car just stopped running in mid drive yesterday. So far here is what Ive checked-
1-The car is getting spark at the coil packs (consistent flashing light).
2-Checked all fuses related to injectors, fuel pump, that stuff-no visible issues.
3-Checked pressure at the source (from the fuel pump under the seat, I couldnt find a Schrader valve under the hood). Here is where it gets interesting.......
When I turn to on position, no humming from the fuel pump. When I turn to crank position, fuel pressure jumps to about 50PSI. Pressure goes away after that.
So I could think Ive ruled out the Camshaft Position Sensor, fuses and relays, coil, and have either an issue with Fuel Pump or Fuel Pressure Regulator???
Thoughts
Old 01-12-2015 | 12:42 PM
Did you scan the computer for trouble codes?
Old 01-13-2015 | 11:49 AM
tjjolle's Avatar
I did, its not throwing any codes, not in limp mode. Thats why I think its the fuel pump or pressure regulator.
mcbakker100
06-19-2017 07:58 PM
efreni
07-17-2010 10:04 PM
ddzc
06-07-2009 08:04 PM
96accent
06-08-2006 02:45 PM
2loud2k2xd
03-18-2006 08:38 PM
