New antenna
New antenna
Hi there,
I own a Accent GS from 1997. Some weeks ago some vandals broke the antenna on the car! [:@]So now I have to replace it with a new (manual) one.
I've found out, that I have to remove the left wheel and the "cover" in on top of the wheel (I don't know what it's called in English). So that I can get to the antenna from beneath.
My question are: Do I really have to replace the wire from the antenna all the way to the radio inside the car? Or is it possible to cut the existing wire and connect it to the new wire from the new antenna?
I hope you understand my problem. I'm sorry for my bad English :-)
Regards,
Kasper
Regards,
Kasper
RE: New antenna
No, you don't need to replace the wire, just the mast antenna itself. The wire should just just unplug from the original antenna without cutting it.
1997 > G 1.5 DOHC > Body Electrical System
ANTENNA REMOVAL AND INSTALLATION
1. Remove the front wheel guard and antenna mounting bolt.
2. Remove the antenna mounting nut.
3. Disconnect the wiring and antenna cable.
4. Remove the antenna assembly.
5. Installation is the reverse order of preceding steps.
RE: New antenna
Thanks for your reply!
My problem is that I can't disconnect the existing wire from the antenna. It's kind of welted on like this one:
I know this is a motorized one, but the wire are connected the my antenna the same way.
I thougth that mabye I could asembly the new wire from the new antenna with the existing wire inside the car behind the glove box?? Or is that a bad idea compared to the loss of signal etc.??
RE: New antenna
I own a Hyundai Accent GLS and due to an accident its antenna got broked therefore I want to know how can I replace its antenna without having much problem
__________________________________________________ _____
richard
http://gmail.com] Gmail Rocks [/url] http://mail.yahoo.com] Yahoo Mail Rocks [/url]
richard
jnezon@hotmail.com
08-13-2007 10:53 AM
