OEM or Felpro gasket?
Old 01-21-2012 | 10:23 AM
Ricklee64's Avatar
Default OEM or Felpro gasket?
I discovered that I had a leaky valve cover gasket. I bought a Felpro gasket which is a normal looking after-market gasket which fills the slot and flares out to the surface of the head. When I went to remove the valve cover, I discovered that it was severely cracked. (I bought this 2003 Accent as used.) So I ordered an OEM valve cover. When it arrived, I was surprised to see that it came with an OEM Hyundai gasket. But the gasket is thin, and inserts into the slot, but has a thin edge. My question is....which gasket should I use? Why would the Hyundai gasket be thin and not flared? Also, what would be the correct torque for the valve cover bolts?
Old 01-22-2012 | 08:55 AM
What engine? 1.5L SOHC or 1.6L DOHC?
Usually it's 6 ~ 7 lb.ft
Old 01-22-2012 | 02:13 PM
Ricklee64's Avatar
It's 1.6 DOHC.
Old 01-26-2012 | 03:48 AM
jmarshall's Avatar
obviously..you should try OEM one. It might be happens that the gasket is designed for all latest models uses same engine as old one. there is nothing like bad effect of the thin one. But dont afraid of the leak problems.it works finely. and the torque required is about 6-7 lb-ft.
Old 01-27-2012 | 01:58 PM
Ricklee64's Avatar
The OEM is the thin one. You're saying that it works well? The Hyundai dealer recommends it of course. The Felpro seems to be heavy duty. Still wondering....
William Alexander
04-24-2015 12:13 AM
edgarnn
11-24-2008 10:50 AM
jimber57yr
09-11-2008 09:55 PM
Zef_66
03-18-2008 11:59 PM
headsupkid01
10-09-2007 09:07 PM
Quick Reply: OEM or Felpro gasket?
