overdrive button
Old 09-25-2006 | 02:47 AM
sidvisious5150's Avatar
Default overdrive button
i have a 97 hyundai accent i got it a couple of years ago. the problem is the overdrive button doesnt work. how would i go about seeing if it is hooked up. thanks in advance for any help.
Old 09-28-2006 | 06:05 PM
SnugglesZeroCool's Avatar
Default RE: overdrive button
The overdrive is normally always engaged and had its pros and cons. on my 02 when i hit the button i get a light that says O/D OFF. Or you could check the power going in and out of the button, check the fuse. to see if it is off and not working floor your gas petal and if it has a slower acceleration then usual OD is off but if it feels right than it should be fine
Old 03-07-2007 | 02:36 AM
stokelife's Avatar
isnt overdrive supposed to be more efficient. I dont have that feature , my 95 accent is 5 speed. But overdrive is a term which means you drive in a higher gear so the engine rotates slower = saving gas. mybe its irrelevant. you basically wonbt have muchtorque in overdrive, out of overdrive you have more. the old torque vs revs conflict
red
09-27-2021 07:06 AM
hicksd67
01-27-2012 07:27 PM
chascornell
07-22-2010 09:32 AM
Davex
10-07-2007 10:48 AM
dennis041948
03-27-2007 01:41 AM
