P0335 error code
Old 07-21-2010 | 12:45 PM
CGBob's Avatar
Default P0335 error code
My teenagers 2000 Accent won't start, cranks over just fine but no spark at any of the fours wires. After plugging in an OBDII / EOBD + CAN Digital Auto scanner, I get P0335 error code and the on screen verb age "Crankshaft Position Sensor A Circuit". Is there a way to check the CPS any further. We brought coil packs on some basic advice & I'd like to check further before buying another part. FYI the car has over 150K miles.
Old 07-21-2010 | 02:00 PM
zero_gravity's Avatar
Banned
look up that error code for that specific car under the DTC section on www.hmaservice.com. you will find full diagnostic procedures there. you must use IE and you must download the adobe plugin under the site requirements page. a free account (username) is needed.
Old 07-21-2010 | 02:32 PM
CGBob's Avatar
tks, i'll give it a try!!!
Old 07-21-2010 | 10:48 PM
hyundai-tech's Avatar
Unplug sensor and ck for corrosion or water. Plug back in and see if it starts. Crank sensor failure common on accent especially with that mileage.
Old 07-22-2010 | 10:51 AM
Banned
question regarding the common crank sensor problem: whats the usual end failure for these? water get into them?
Old 07-24-2010 | 08:57 AM
Most I have seen that have failed have actually been corroded connectors..aterin em stuff like that. Now less that half are just open circuits internal.
Old 07-25-2010 | 12:54 AM
Banned
good to know, if i'm starting to get that some dielectric grease may be in order
Old 07-26-2010 | 08:45 AM
CGBob's Avatar
i check the old one w/ a multi-meter, it was bad, bought a new CPS for 30+ bucs, and she runs fine.
mwaterous
03-14-2021 05:03 AM
tedallen
10-17-2012 12:09 PM
chasf111
06-08-2011 07:24 PM
2000ElantraMatt
03-18-2010 06:47 AM
miniwangja
06-12-2009 06:49 PM
